Wiring Question
Wiring Question
Does anyone know if there's a way send a wire from the main cabin around the dash area into the engine compartment? I'm trying to wire up an airhorn speaker that will be mounted in front of the radiator, as well as some strobes mounted behind the grill. Basically, need to get 2-5 wires run back there (I'm mechanically capable, will drill if I have to but as a last resort, there must be a grommet or something i can poke through). Either the driver's side or the passenger's side works, but driver's side preferred. TIA>
Re: Wiring Question
Open the ecu there is a big space in the back towards the pass. side you can see the drivers floor run the wires down through there after that you should be okay...prob can run the wires on the drivers side near the fender under the weatherstripping towards the front of the car....
Audifastdaddy
13
06-05-2023 01:55 PM
CRAZY_RUSSIAN
9
09-10-2015 08:39 PM
stormchaser1967
09-02-2015 09:26 AM
