Would this speculation/theory be far fetched?
#22
I hammer it at the same speed in the same gear? I just find it strange that it only happens once in a while.
I can add another person in the car to having 4 people and trying to do it, still can't reproduce it. It only does it when it wants to then goes away.
#23
But theres only a few situations where your clutch would fail/slip. I've seen some clutches that were down to metal on metal and still held like normal. Then i've seen some that were metal on metal and wouldn't hold for crap.
Yours might be worn just a hair enough that it slips but catches. the fact that it is getting more frequent is a sign that its prolly going to go sometime soon, as in a year or so. Like others said it cant be oil because its not happening when the car sits over night or something. Its when the car is rolling so the oil would be all on the outside of the inside of the tranny housing.
Also the slipping might heat the clutch surface up a little so that it makes it a tad wider and a hair more sticky, and thus regrabs itself.
#24
I only noticed it when I went stage 1, under stock HP the clutch was fine. I have 154k on my B5 and no issues with the rear main seal leaking.
#25
nothing major. I figure I need a replacement sooner or later but if it can hold out longer, why not
#27
engine but otherwise the set up works well. I think if I had known more I would have gone with a Southbend but this works well. Basically I think it is the B5 S4 clutch set up adapted to work on the 1.8T
Oh I had no leaking on the ground that I ever noticed.
#28
There was a significant leak at the input shaft. This, in combination with a worn clutch, caused significant slipping. It started in 5th gear only at low rpm highway acceleration and gradually (over the course of 5 months) was pronounced in nearly ever gear under any load.
Had the leak been identified earlier, I would still be on the stock clutch. That said, I couldn't be happier with the new Southbend clutch.
<img src="http://pictureposter.audiworld.com/54173/bell_housing.jpg">
#29
the clutch down because of added lubricant and eventually was noticed when the clutch was fully engaged in 5th?
Doesnt make sense that the oil would get on the clutch/flywheel when its moving and cause a problem.
#30
moving or not, the plate was probably compromised over time. Prolonged driving did not help or hurt the situation.
