WTF is up with my boost curve?
K04 w/neuspeed software, forge 007 DV w/blue spring.
slow ramp up indicates a boost leak methinks, but WTF is going on > 5250 RPM?
<img src="http://pictureposter.audiworld.com/52813/boost.2.jpg">
I know I need to do some additional logging still
after reading the post below I had a revelation...
it's my fuel pump/filter. I've been hearing a slight whining coming from under the back seat area. If the fuel pump is straining and not delivering the requested fuel, that could certainly cause the irregular boost, right?
yeah you'd also throw bank 1 lean codes
go log the air fuel rate and CF/KNOCK VOLT.
looks like surging to me, maybe you do have a boost leak causing the turbo to spin faster than it is to produce the requested boost.
