Your experience with ski/bike racks and audio mods
#11
I like it, esp. in red. How would you hook it up? (more)
Have you thought about installing the box under the seat (where the storage compartment is)? Would this make the wiring easier? Also, if you installed the wired remote where the ashtray is, how would you run that wire?
Is there any info on the Symphony II online that you've been able to find?
#12
Answers...
<i>Have you thought about installing the box under the seat (where the storage compartment is)?</i>
I actually think it will fit in the glovebox, which is where I would want it. No chance of being kicked and it's not visible. If it didn't fit in the glovebox, I'd probably opt for the trunk.
<i>Would this make the wiring easier? Also, if you installed the wired remote where the ashtray is, how would you run that wire?</i>
If the unit will fit in the glovebox, you can easily run the wire from the remote through the center console to the glove. If you tried to put it under the seat, you could run the wire down from the center console inbetween the seats and conceal it that way.
<i>Is there any info on the Symphony II online that you've been able to find?</i>
Do a search on the forum. Someone removed the Symphony II and took pictures of the pin-outs and connections on the back.
Good luck...
Good luck...
xkahn
02-08-2018 10:43 AM
chihashu
01-28-2016 05:59 PM
Zumkopf
09-04-2015 03:06 PM
