Are your tires inflated with Nitrogen?
.....if so, how do you like it? I had the air purged from my tires and then inflated with Nitrogen. Service center supposedly put 30psi in each tire. I checked pressures a week later and none of the tire pressures were at 30psi. Infact, they were all different, ranging from 32psi to 40psi. I readjusted pressures to 30psi a couple of days ago, will recheck pressures in a day or two. Service Center also put green valve cover caps on my stems, ugh.<ul><li><a href="http://www.nitrogeneration.com">http://www.nitrogeneration.com</a</li></ul>
as compared to 225/40/18? My tires are rated to 40psi and I usually fill to 37-38psi.
I personally have never tried it. My old roommate had an E 320 that the dealer filled with nitrogen. I didn't notice a difference though.
In any event 30psi seems a bit too low for low profile tires. You might ending up bending a wheel if you hit a big pot hole. Try it at 35psi and if you don't like it you can always deflate the tires.
I tried my setup on 32psi (dealer deflated it from my usual 35psi during the last visit) and I thought the ride was a bit floaty. I now run 37-38psi and I like it more than 35psi I was running before.
