18x8.5 BBS CH on B7s
Hi
I'm looking at purchasing a set of BBS CH fitted with PZero Rosso. A few questions:
1. The offset is 35 on those 5x112 pattern 18x8.5 BBS CH while it is 42 on B7s I believe. What will this result in, apart from tires sticking out more?
2. Will there be any kind of rubbing, at all, after a drop using H&R sport springs and Bilsten shocks (a drop of 1.5 front and 1.4 rear)?
3. Is 225/40/18 suitable? If not, what problems will I come across?
4. Would it be necessary, or better for me to change to 235/40? What difference will this make?
5. Is there an OEM Audi cap for BBS CH? Are they the same as those new S4s?
6. So, running an offset that is far from stock, and on a car that is dropped, will there be any implications in the long term? I ask because the parts manager at my local dealership tried to scare me off by saying it could void warranty on certain parts by running the above set up.
Thanks!
Thanks!
This in turn would jeopardize the cornering... 235s are the perfect fit for 8.5 width rims....
The offset difference would be 7mm in terms of sticking out... This would not hurt even if you lower the cars. There is plenty of rooms... If you go wider than 235s such as 245 or 255s I am sure it will rub in the rear...
not true....not always true at least
tires are like shirts. A 225/40/18 from one firm can be as wide as a 245 from another. You need to look on the manufacturers site, as they all list the physical dimensions, as well as recommended wheel widths
yes the offset is higher than a stock B7 - but the width is increased as well. As a result, they won't sit much different from stock - slightly more aggressive, but nothing major
And its lowered about 2" if not more. You'll be fine.
<IMG SRC="http://www.speedsportlife.com/photopost/data/780/IMG_8434.jpg">
whats up Alex, I tinted 30% Huper Optik (Pro Tint)
I am holding off on rims probably till early next year. I am leaning towards 7 double spoke 19" rs replicas
Car is running great 1,700 mi
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
Audi Other S6 2002 FS
dorschman
09-17-2015 03:24 PM
Audi Other 14 inch bbs wheels 4x108
Jiggie
08-30-2015 06:37 AM
Chigger
08-27-2015 11:07 AM
