A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
2.0T FSI coolant leak
Old 11-13-2008, 07:17 AM
ksalno's Avatar
Default 2.0T FSI coolant leak
My wife took our 2005 A4 2.0TQ in for service. I had noticed a couple of times (not always), the car had a small pool of coolant under the engine in the middle between the front wheels.
They initially said it was a seal (she didn't know which one) and it would cost $400 to repair. When she went to pick up the car, they told her it wasn't the seal, it is the head gasket and that will cost $2500 to repair.
I'm very skeptical about the head gasket. I've blown head gaskets on other cars and you know when they go, they don't just periodically drip some fluid. I changed the oil and there is no sign of water in the oil and the coolant leak is sporadic. My wife does a lot of short trips, so it could be the engine isn't cooling down properly and overflowing.
Anyone else had this problem?
I think I will at least take it to another dealer for diagnosis or maybe to an independent.
Old 11-13-2008, 08:04 AM
AudiWorld Expert
Reggie's Avatar
Default Worth taking to another shop (think independent shop - check your local forums for recommendations)
I like you think the odds are it is some other issue, but clearly something is wrong and the wifes driving habits are not going to cause this.
Old 11-13-2008, 08:58 AM
OneEyedJack's Avatar
Default The coolant flange on the back of the cylinder head is known to leak
This may or may not be your problem. Many, including myself, have had this flange leak. Dealer replaced under warranty, but the part is less than $20 and fairly easy to replace.
Have a look at the backside of the cylinder head and look for any pinkish chaulky residue near the plastic coolant flange. It is easier to see from underneath but topside should do.
Also, do a search for coolant flange. This is a known weak-link and is not just isolated to the 2.0T. Many 1.8Ts suffer the same problem.
Old 11-13-2008, 09:08 AM
Senior Member
lowdef's Avatar
same here.
Old 11-13-2008, 01:57 PM
RichAA's Avatar
same here
rsd911
30
03-14-2019 10:14 AM
Canon
03-29-2009 06:09 AM
TOMAS7
07-26-2008 05:20 PM
Binx
05-05-2006 12:44 PM
Bvarghese
10-26-2005 02:02 PM
Quick Reply: 2.0T FSI coolant leak
