2007 A4 2.0T In Limp mode PRNDS all lit up, car wont shift out of park
Picked up this car the other day, its a 2.0T 2007 A4.. It has the CVT I believe if I'm reading the part numbers correctly on the transmission . It wont shift into neutral, or move, The tires are locked into place and it wont roll.
At one point it slipped into Neutral somehow, the car started rolling back.. But its now still stuck back the way it was with the wheels unable to roll.
Also it is really difficult to move the shift **** any lower than Netural, it gets really tough to move back and kinda mushy if that makes sense.
All the PRNDS lights are on..
Update, after clearing the codes with my ODB2 reader, or right around the same time, the shifter was able to move up and down freely without any difficulty, Also after clearing OBD2 codes, Gear Indicator lights went back to normal, the car acknowledges now that the shifter is being moved around, but still wont shift into any gears and wheels are locked)
Another update, I got my VAG cable today and the logs are below. Also the shift movement became difficult again tonight like it was before. It very hard to pull back on the shifter past N
Should I replace the 2 sensors throwing the codes, or is this the TCM? Does it need to be sent out and re-flashed by one of those companies? OR is it the whole transmission??
Anything specific I need to do with the VAG com to diagnose this better?
Im gonna check the ATF fluid level in the morning.
Any ideas would be appreciated...
Here is the VAG Scan Logs.. Also the battery was dead, Ive charged it since, but haven't been able to drive the car, so I assume that's what all the Voltage codes are for?
NEW UPDATE,
I pulled a TCM off another A6 at the junk yard. The stickers in the trunk and engine said it was a JTT Transmission. I installed it into the car, and its still in the same position it was in. All the lights come on when you turn the car on. If the codes are cleared and the car is just on but not started, it slects all of the gears when you move the shifter, but when you start the car, all the lights turn on and solid, and it wont shift out of Park..
The 2 speed sensor codes still come up when I scan it.
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 8E1 910 115 G HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0010
Revision: 5EH15--- Serial number: XXXXXXXXXXXXXX
Coding: 0104010A02070120
Shop #: WSC 07109 444 54528
VCID: 26443ABA918B1071B3-8072
1 Fault Found
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 153042 km
Time Indication: 0
Freeze Frame:
RPM: 1106 /min
Load: 35.7 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 10.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.970 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 M HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0020
Revision: 00000012 Serial number: 00000002049340
Coding: 0000001
Shop #: WSC 04940 001 00001
VCID: 326CD6EAAD437CD12F-8066
2 Faults Found
001826 - Transmission Output Speed Sensor (G195)
P0722 - 000 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1216 /min
RPM: 0 /min
(no units): 13.0
Torque: 18.0 Nm
Temperature: 7.0°C
T.B. Angle: 0.0°
Bin. Bits: 0011 0 0
006035 - Transmission Output Speed Sensor 2 (G196)
P1793 - 000 - No Signal - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Address 03: ABS Brakes Labels: None
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004525
Shop #: WSC 06325 000 00000
VCID: 2C50C8928F672A2165-8078
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 35
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x5002
Hex Value: 0x0024
Hex Value: 0x017D
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DD6059627FDE32932-513C
1 Fault Found
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06325
VCID: 3D76F5D6371DB3A9C2-4B18
1 Fault Found
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
NEW UPDATE,
1 Fault Found
P1624 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 153042 km
Time Indication: 0
Freeze Frame:
RPM: 1106 /min
Load: 35.7 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 10.0°C
Voltage: 13.970 V
Coding: 0000001
2 Faults Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1216 /min
RPM: 0 /min
(no units): 13.0
Torque: 18.0 Nm
Temperature: 7.0°C
T.B. Angle: 0.0°
Bin. Bits: 0011 0 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Coding: 0004525
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x5002
Hex Value: 0x0024
Hex Value: 0x017D
Hex Value: 0x0000
Coding: 00000
Shop #: WSC 00000
1 Fault Found
Coding: 00003
Shop #: WSC 06325
1 Fault Found
mobe
15
02-28-2006 08:10 PM
