AC won't blow cold air
#11
I'm getting a G65 High pressure sensor error. I've reset it twice but it still comes back.
The symptoms that I have is that the climate control always stays on ECON mode.
I was quoted a price of $80 +tax for the sensor from Audi.
#12
I have the same problem, no cold air. I had the A/C charged last year and worked but was empty 10 months later. I have taken the car to a garage and been told the pressure sensor is leaking.
I have replaced my self the pressure sensor, took it to a shop recharged the A/C but still not working.
The scan revealed this (United Kingdom car):
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 30
Reset counter: 25
Mileage: 253116 km
Time Indication: 0
Date: 2016.12.29
Time: 16:22:15
With new sensor installed and no leaks something is preventing the compressor to engage. Any suggestions? Do I need to clear the DTC's?
Thanks
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 25
Mileage: 253116 km
Time Indication: 0
Date: 2016.12.29
Time: 16:22:15
Thanks
#13
so far here is what I have: cant clear code on computer....red lead from high pressure control switch 10.5volts.....middle wire striped shows 100 percent open.......new pressure switch replaced
economy light stuck on......freon ok.......not sure about ground.......HELP
Screamin' Cactus
07-10-2001 10:04 AM
