Anyone know if the fjront B7 brake pads have the wire connectors on them? I just bought some Hawk H
You'll have to short the wear sensor circuits or you'll have a warning light on your dash. Just stick a wire in the end of the plug when you change the pads.
You'll be fine without the wear sensors. Just keep an eye on pad thickness.
I put the HPS pads on because I'm doing track days. I just check the pads when I swap the track tires. Or use a technique I saw in tech - checking the pads using a small narrow penlight so you can get it close, you can see how much is left pretty easy that way.
Question - on my 2008, the HPS pads didn't fit the rattle clips, so rattle clips out and now the pads rattle. But not enough so it matters to me. Do your's have the rattle clips in?
Fast Euro
11
01-15-2008 08:23 PM
Kirath ¾-B0§t0n
06-26-2003 07:50 AM
ToddM
07-20-2001 10:50 AM
