Last edit by: IB Advertising
- Audi A4 B7 and A4 B8 How to Change Power Steering Fluid<br>Step by step instructions for do-it-yourself repairs.
b7 power steering fluid
i have a 2.o non quattro b7. the power steering fluid has run dry but no one in my country seems to know which fluid can be used. someone suggested valvoline dex/merc. can anyone say if this oil will work or ruin?
Len, not knowing what country you are in, the only acceptable fluids are:
Pentosin CHF 11S
Pentosin CHF 202
It's a semi-serious issue to let the pump "run dry".
Do NOT run alternate fluids. You'll be in for a complete system rebuild following that. HTH.
Welcome aboard!
Pentosin CHF 11S
Pentosin CHF 202
Welcome aboard!
thanks. i am in guyana, south america. there is no audi dealer and therefore no access to a parts bin. but your advice taken on board. it will have to wait until i travel and find the right stuff...
Len, any sightings of Jim Jones??
I truly pray that your power steering pump can hold out...
Best of luck.
Best of luck.
lol. i had the misfortune to have been in the first wave of journalists into jonestown after the mass suicide. it wasn't a pretty sight nor smell!
I will park the car until i can get the oil. fortunately there is another car.
cheers
cheers
In that case, you're dating yourself if you remember that!
Glad to hear there's alternate transportation. Good luck with it!
Bogota:
http://co.traetelo.com/autos-motos/a...12_m19017.html
Audi has a presence in Venezuala.
Mercedes uses the fluid in many of their vehicles as does BMW...
Volkswagen uses the same fluid.
Bogota:
should be the Pentosin green can hydraulic fluid. Also the problem could be the filter in the reservoir. It gets clogged and fluid over flows and leaks. Usually a new reservoir fixes the problem.
