Best way to go about painting brake calipers?
I want a nice porsche red brake caliper set. What's the best way to go about this? How hard/easy is it to paint these things? Do you need to disassemble the brake unit or can you do it on-wheel? What paint do you use? Any over coat? Wanna make it last as long as the car and look OEM quality. Thanks
1) You could mask off just the parts you want to paint, use Hi-Temp engine paint from your local auto parts store, and it will look great.
2) You can buy a 'brake paint kit' and use that. (more $$)
3) You can pull your brakes off, take them to your body shop for them to prep the parts and then bake on a finish. (even more $$)
#1 has worked for me several times. Make sure you use a lot of brake cleaner before painting and the paint will stick well and last.
I did mine this weekend, and they look awesome
i just jacked each wheel up, took the wheel off, taped of areas i didn't want to paint, then carefully painted where i wanted it.
i used a G2 paint kit, it worked well
Just wondering, will the result difference will be noticeable? Also, will the paint fade away by time? I am thinking to paint mine black. I don't want it to become gray overtime
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Your mileage may vary. For me I never had to re-paint, but then I don't know what wheel cleaner you're using. If it's strong enough to eat through paint I wouldn't use it on my wheels...
Cmmartin23
26
08-23-2016 04:44 PM
Audi Other Audi RS2 (recreation) for sale
Georgi_Kirov
09-15-2015 11:11 PM
