Bought the Diverter Valve Spacer.....
#11
Absolutely. You have to take your DV off, put the spacer on then your DV will simply fit over it. I think it will actually work better with yours then the OEM one. I have mine attached to the OEM DV but yours will fit fine if not better. And id get it man, its cheap and sounds great and no it doesnt replace the DV it simply attaches to it.
#12
It took me about 50 mins to instal. That includes jacking up the car and taking the mud guard off the bottom too. now, what i did was jacked one side all the way up, put a jack stand under the sway bar near the tire, then jacked the other side up and put a jack stand under the other sway bar. Leave the jack under it decompressed slightly for extra precaution and chuck the back tires, if on a slope. Get under loosen all the twist screws for cover, take cover off then reach way up to the bottom of the turbo and simply take off the screws of the dv and pull it of and slap the spacer in!!! I never done this before so 50 mins for me will prolly be like a half an hour to alot of you.
#13
Also, if you havent already, check out the vid i posted on a thread of how it sounds. Its of how it sounds in the car, keep in mind it will be louder outside the car
#14
Thanks for the feedback and video, now i know what i am buying this weekend
#16
I installed one on my car this past week and its kinda quite and its not really a blow off sound.... its more like a semi letting out the air brakes! I will be weldind up an adapter piece to try and put a (real) BOV on my car... or i will block off the original space using this DV but blocking off all the holes, and putting on a BOV on the hard pipeing when i install my FMIC
#17
#18
eBay, classifieds here, Audizine or VWVortex classifieds, I just sold mine a couple days ago. Pretty sure there are 2 for sale on Audizine right now.
#19
