Brake lights stay on all the time
#11
#13
What was the function of the fuse? I have the same problem on a 05 A8 and would like to find the comparable fuse.
#14
Just want to thank this thread, fitted new brake light switch, took me straight to where I should be looking, sure enough, found fuse blown under ECU cover, replaced saved me a fortune as garage had no idea what to do next. They have also learn from this experience so yes, very happy days!!
#16
got same problems and drain my battery over night fews times now due too temperature change.what is the fix please.thanks
#17
#18
Hi There,
#19
Solution It痴 the 614 relay
So I believe I found a solution next to the ECU you have a few relays, The wiring in the ECU is tightly packed firstly move the ECU out of the way then take all the relays out,
Next remove the female relay connectors from the cage and untangle all the wiresThe lazy bastards Audi just force all the wires without thinking twice while making the car
Next re-root the wires and put the connectors back in the cage but make sure the wires are nice and neat and not twisted then without forcing the wires click the cage back into its position definitely use some WD-40 on the connectors Then put the relays back in.
Now I found the 614 relay or all the wires to it was causing my brake lights to stay on the relay must power other circuits because I got a lot of short to grounds and intermittent faults all at the same time so this relay powers other things And every time I took the really off the car my brake lights would go off I知 going to do a YouTube video anyway I値l post a link in a few days
#20
