Brembo 345mm rotor upgrade
Hey Guys,
I've been doing some research and it appears that the Brembo site lists a compatible rotor under the Audi S8 for the 345 brake rotor upgrade for the B7. Of course we would have to purchase the audi OEM B7 S4 Brake Caliper carriers to do the conversion but the swap should be relatively easy in order to increase the stopping power of our stock calipers.
Can anyone double check the specs and see if they match? Copy and paste the link below. Select Audi, then S8.
http://www.brembo.com/CatalogoHP/Templates/SearchHP.aspx?NRMODE=Published&NRORIGINALURL=% 2fENG%2fPerformance%2fCatalogue%2fsearchDisc%2ehtm &NRNODEGUID=%7b63F2F2F3-F471-4D3D-BD56-7D10C1FD4F7D%7d&NRCACHEHINT=NoModifyGuest
But with Brembo cross drilled or slotted rotors. It should cost no more than $500 for the setup. Imagine 345mm brakes for $500. Can anyone confirm?
Audi Other 6 speed 2003 Audi RS6
alpinab7
10-07-2015 10:13 PM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
