When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Does steering control module need to be programmed.
I’ve been having issues with my Audi a4 for two months. After much diagnosing I narrowed the issue down to the steering control module. Grabbed one from the scrapyard and installed. Still same issue no horn, airbag, steering controls etc. Then when I have that 10amp fuse plugged in the climate control doesn’t work. When I pull it all is normal. Do I need to program this module? I’m so frustrated with this car. I’ll add the errors I got after replacing the module.
Thanks
I’ve looked at about ten grounds thus far. I’ll have to keep looking for more. I also have a voltage drain from that cable that connects to the positive terminal. I know it goes to the alternator do you know if it connects to the ignition switch?
