Door handle (outside) trim is loose
Hi there, I have a Q7, but my neighbour (UK spelling !) has a B7 A4 Avant. Simple problem. The outside door handle has a plastic body coloured (UK spelling again !) trim piece on it. This rattles. It rattles when you tap it.
Looking under it, there seem to be two plastic lugs that may or may not, hold it to the actual bit that does the work. Don't want to try to pry these as they're sure to snap.
Anyone had this problem, and what was the fix ?
Thanks in advance
Paul
Thanks in advance
Paul
Same problem
Wow, what a coincidence, I JUST noticed this same issue over the weekend with my B7. Unfortunately I haven't been able to identify how to fix it. Hopefully someone else will have an easy fix?
Rory
09-13-2004 03:08 PM
