Last edit by: IB Advertising
- Audi A4 B7 How to Fix One Touch Window Up Down<br>Step by step instructions for do-it-yourself repairs.
Driver's door window no longer has the Auto one-touch down feature.......
It will still go up with the Auto one-touch but not down. I ran my Vag-Com on it and no fault codes showed up. Any ideas from the brain trust?
Any help will be appreciated.
I have '06 A4 as well with the same problem. There is a process to reset the auto up using the window switch but I have not seen anything for the auto down. I also find the auto up to be sensitive and unpredictable - although I have seen several posts noting the crazy window controls on the Audi. I'm new to the Audi so have little experience. I too will be very interested in any suggestions.
btw, what are VAG codes.
Phil
Phil
I currently have the same problem. What I do is with the window up, push and hold the button down and hood it down for 10 seconds. Than hold the button in the up position for 10 seconds. You do all this without letting go of the button. By the way, you do this with the car running. It sometimes resets and works.
LukeHawk (06-29-2019)
Phil
Phil
evil twin beat me to it lol yes all u do is hold it down for 10 seconds, then hold it up for another 10. If that doesn't work, keep messing with it by holding it up and down and it will start working. I've had to do this a couple times on my car.
my battery just died and was replaced and weird things are going wrong. auto up/down on the driver door window was one of them. this fixed it. thanks and thanks to the OP for bringing it up.
Thank you for this. I just left Jiffy Lube and my auto windows were no longer, but rather than dwell on my thoughts of window terrorism by the local lubbers, I found the fix here. May the Audi Gods bless you rides!
-tm
=3Vil_twin;24043058]I currently have the same problem. What I do is with the window up, push and hold the button down and hood it down for 10 seconds. Than hold the button in the up position for 10 seconds. You do all this without letting go of the button. By the way, you do this with the car running. It sometimes resets and works.[/QUOTE]
-tm
So my "Auto one touch" works but doesn't always bc the switch actually broke. There's 2 clicks in the switch and the click that controls the auto up got broke or wore out bc the switch is loose. I can however make it work if I hold it a certain way. I'll have to buy a new switch if I want it to work properly.
