Fans not working, changed module still noting!!!!!!
As I stated my a/c stopped working about a week ago whenever I would be stopped for more than a minute. While driving with no traffic the a/c blows cold. So i found that neither of my fans were operating and had voltage entering the fan control module and not exiting it. I jumped the fans to the battery and they worked fine. So from my findings and a little research here i bit the $275 bullet and changed the module. Now the fans start up for about 5 sec and then cut out. This happens about once every minute. Checked the voltage when this happens and it will reach about 8 volts and then cut out. I really don't want to spend another $500 for new fans if im not convinced there dead. Any info will be greatly appriciated, thanks in advance.
I've also been having some trouble with my a/c fans as well as the compressor. I've had this happen 3 times so far, but when I'm on the highway, with the a/c blowing steadily, I've pushed the car to pass people and the fan seems to cut out, the monitor reads that I've got full fan speed and I can hear air rushing out of the vents but nothing is coming out. I've also been hearing some groaning when I start the car with the compressor off and an extremely rough idle when I start the compressor. Have you had any similar problems?
mel g
05-16-2006 05:24 PM
