Front and Rear Sway Bar H Sport Install
Has anyone installed the H Sport S4 sway bars on there car before? I was wondering where the front sway is located and how to get at it. The rear is easy but i have not found anywhere on the internet a person who has done the install and posted pictures.
Former Vendor
It's pretty clear once you remove them. The front is easier than the rears.
H-Sport includes installation instructions as well.
You need to remove the belly pan and its right there. Its a much easier install than the rear bar
<img src="http://pictureposter.audiworld.com/105649/front_sway.jpg">
They have instruction manuals.<ul><li><a href="http://www.hotchkis.net/files/installation_guides/22823_22829.pdf">http://www.hotchkis.net/files/installation_guides/22823_22829.pdf</a</li></ul>
Thanks for the pic. I actually was able to see it once i put the car on ramps. It is visible through one of the belly pan vents. And you are right much easier to install then the rear. I had to undo the rear exhaust brackets to install it. What setting did you put the rear on, the first hole or the second? i could only install the bracket on the first hole.
John
John
Just as a follow up to all the posts. I have installed the front and rear bars and have taken the car for a little ride with them on and i can def. feel a difference on tight corners and turns. I highly recommend them, and make sure you get the S4 bars. They have a thicker rear bar then the A4 setup and they both fit the A4. The only question i have to anyone that knows is what hole should be used in the rear on the ends of the sway bar?
On the underside of the control arm there are two bolts that hold the thingy that the sway bar bolt goes in to. What you need to do is loosen those bolts significantly (but don't remove), then move it over to the stiffer hole, tighten that bolt, and then go back and tighten the lower CA bolts. Repaeat on the the otherside and you're good to go
shadyraven
Audi allroad
05-26-2008 01:53 PM
a4tis™[Bye Turbo]
25
08-28-2006 03:07 PM
CasaS4
06-05-2002 12:40 PM
