Front Wheel Bearings
So I took on the task of replacing my front wheel bearing and things were going too smooth. As shown below I have taken out the four hex bolts that hold the bearing and hub to the axle(?). From the two DIY's I've read, after taking off the four bolt the housing should come off with some strong but not forceful encouragement from a rubber mallet. I have sprayed the inside(since the bearing will be replaced anyway) and the outside with PB blaster hoping to loosen the corrosion or rust. After 2 hours it still has not moved a cm. Does anyone know why its so stuck, or is there something else that needs to be taken off first?
Thanks!
Thanks!
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
Curtisjh
09-04-2015 04:06 AM
stormchaser1967
09-02-2015 12:47 PM
Al_Bundy
09-02-2015 07:24 AM
