Frontbumper alignment?
I have a problem after i had my front bumper off the car.
I cant get it in right positions.
Its about 1cm to low, is it possible to correct this, what can i have done wrong.
Guys
I need some advice relating to this topic please - I have this weekend swapped the S-Line grill that I had on my car for an RS4 one. Took the front bumper of etc etc - took ages!!!
I reinstalled the bumper did all the bolts and fixings up and shut the bonnet. I have noticed that the bumper on one side is slightly lower that the other. I suspect that these screws may have changed height when I took the bumper off. I am confident that it is sitting correctly as per the isnstructions, I was wondering whether it is possible to adjust the height without going through the lengthy process as per a full removal.
I notice that as you look at the slam panel above the radiator grill there are 2 little holes which line up with the top of the screws in the picture. If I can get a torque bit to these and turn these does it make a difference with alignment? Does it raise or lower a side?
Thanks for any advice,
Mootee
Mootee
heretic
01-28-2006 05:25 PM
t0adman2.8
Pacific Northwest Discussion
11-05-2004 08:38 AM
mdwsta4â„¢uroslut
03-31-2003 11:47 AM
