how to install LED light 2006 audi a4 2.0t Q
Hi,
if you guys can help me to figure out how to install LED light and is it really simple or hard about wire and connector and does the online LED light really works as same as original one . any recommend
thank for every body help
You should do a search for LED in the various Audi forums. LED's can be retrofitted quite easily but you will need to install additional resistors to avoid the various "bulb out" warnings that will occur because LED's draw much lower current than the standard tungsten filament bulbs.
Coupe_20v
05-12-2003 05:45 AM
