License Plate Lights...
Has anybody....anybody...I mean anybody found a decent LED replacement for the license plate lights that DOESN'T TRIGGER THE BULB OUT WARNING in the dash? I've tried about 5 different types now, all of which have claimed that they don't trigger the warning..
BTW, I have the color dash computer, 2006 MY.
Cheers,
Nick
Cheers,
Nick
Same here every one of them triggered bulb out warnings even though the seller told me it will not. I lived with it for a while, but started to bother me. So I just added resistors since led lights do not comsume enough Watts to fool the system. It was pretty easy job. Did them in less than 30 min
1 watt 10 ohm or similar? Is there ample room in those inlets to prevent melting etc? Some details would be great...I'll probably end up doing the same..
Cheers,
Nick
Cheers,
Nick
I ran into the same exact issue. I went through 3 different sets all saying they sold "the bulbs" that wouldn't give an error. None did. I found this article recently that solved my problem. It involves buying and installing a resistor on the wires that feed you license plate bulb. Hope this helps you out, it did me.
http://nickscarblog.com/diy/led-lice...s4-2005-5-2008
http://www.audizine.com/forum/showth...ED-Plate-light!!
Cheers,
Nick
Cheers,
Nick
Kenneth Peter Delgado
03-06-2017 11:26 AM
addìct
11-02-2006 06:09 PM
the red pill
04-06-2002 08:31 PM
