Need Audi-recommended tire inflation pressures for Avant S-Line
My '06 Avant 3.2 is not an S-Line, but I replaced the stock 17s with 18" S-Line replica wheels on 235/45-18 Kumho ECSTA ASX ultra high performance all-season tires.
The sticker on the door jamb (or wherever I saw it) doesn't show recommended tire inflation pressures for an 18" tire, presumably because mine was not factory-equipped as such.
Can an Avant S-Line owner (preferably 3.2 since it is a little heavier than a 2.0T) please inform me of the suggested front/rear inflation pressure ranges (empty and full-load) for an Avant S-Line?
Thanks for any help!
AudiWorld Expert
I have an S-line B6 A4...the more important thing is to make sure pressures are even between tires. If you see more wear on the inside than the outside of the tire, over time, then adjust the pressure down to 36-38 psi.
Avant XP
02-24-2006 09:19 AM
audirb
08-07-2004 03:11 PM
Thermal
08-13-2001 06:44 PM
