Need help with Sirius Install/CAN-BUS setting
<center><img src="http://pictureposter.audiworld.com/122270/can-bus.jpg"></center><p>I have the Sirius module installed, no brainer, but I am trying to get the CAN-BUS setting moved over to the left position as is posted on AudiWorld. I cannot get the piece out. Any advice on how to get it out? Any special tools? I don't want to yank to hard and break it....
No special tools needed...
You need to pry back both of those little "U" shaped clips on the top and bottom of the plug. To do this, I first pried one back enough to clear the wedge and then wedged a flat-head screwdriver under there to make sure it didn't slip back on. Then I repeated the process on the top with another screwdriver. Once both "U" clips are clear, a little gentle rocking should unseat the plug.
BigPatsFan
04-12-2004 08:13 AM
T-28-Quattro de VT
03-07-2001 05:41 PM
T-28-Quattro de VT
03-06-2001 09:09 PM
