Need some help PLEASE, Vag Codes Listed and I did search already!
I would greatly appreciate any help and/or recommendations. I have a 2005.5 B7 A4 2.0T Quattro and my CEL went on for a week or so and it went off by itself yesterday. Since the CEL went on, I've heard this humming/whirring noise when accelerating and turning. I didn't get around to using the VAG until this AM, but I listed to the fault codes below. Also, I just took my car to the stealership for an oil change and they stated that I need a new "Prop Shaft Seal" w the part @ $45 and labor @ $420. Would this have anything to do with this? Is there another name for the Prop Shaft Seal? Can someone please explain what that is?
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 8
Mileage: 130610 km
Time Indication: 0
Freeze Frame:
RPM: 2529 /min
Load: 81.9 %
Speed: 119.0 km/h
Temperature: 84.0∞C
Temperature: 33.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 13.335 V
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 6
Reset counter: 99
Time Indication: 0
01213 - Belt Tensioner Igniter; Rear Middle (N198)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Mileage: 130610 km
Time Indication: 0
Freeze Frame:
RPM: 2529 /min
Load: 81.9 %
Speed: 119.0 km/h
Temperature: 84.0∞C
Temperature: 33.0∞C
Voltage: 13.335 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
I don't know the codes or have a vag com, but you might find what you need on audizine. If you are not familiar with the site:
Just go to www.audizine.com, forums, a4 b7, then look in one of the top two stickies. I think they cover vag code or have a link to it.
Good luck
Good luck
Anyone have a VAG in or around Northern DE? Need some help with codes and some overall advice on the
gohardRgohome
01-29-2008 06:36 AM
TooSlow
VAG-COM Discussion
11-13-2006 09:39 AM
AcesFull
08-02-2004 02:00 PM
FreeRideXX
05-20-2004 03:22 PM
