Purchased 91 Y tires by mistake :(
Stupid me thought I'd got a great deal on a set of used PS2's and got them mounted and installed on my 07 A4. On closer inspection I notice they are Porsche rated at 91Y and apparantly I needed 95Y. How dangerous is it toi continue running with these tyres mounted?
thanks
thanks
I'm not an expert but as long as the fitment and load rating are within tolerances and the speed rating is on par with how fast you drive, I think you should be fine. I think you are referring to load rating which, unless you load your car down, shouldn't be a problem.
Here's a chart of load ratings for tires. 1356 lbs vs 1521 lbs per tire.
Load Index Pounds Kilograms
71 761 345 91 1356 615
72 783 355 92 1389 630
73 805 365 93 1433 650
74 827 375 94 1477 670
75 853 387 95 1521 690
76 882 400 96 1565 710
77 908 412 97 1609 730
78 937 425 98 1653 750
79 963 437 99 1709 775
80 992 450 100 1764 800
81 1019 462 101 1819 825
82 1047 475 102 1874 850
83 1074 487 103 1929 875
84 1102 500 104 1984 900
85 1135 515 105 2039 925
86 1168 530 106 2094 950
87 1201 545 107 2149 975
88 1235 560 108 2205 1000
89 1279 580 109 2271 1030
90 1323 600 110 2337 1060
The lowest minimum on any sub-models of the A4 line is 93. The fact that the difference between your tires and factory minimums for your particular is about 200 pounds (in our opinion), it's not recommended and could pose to be a potential safety issue.
SullyS4
13
03-07-2007 07:46 PM
M3iRiSH
15
09-09-2004 06:02 PM
Maini
Audi 100 / A6 (C4 Platform)
07-19-2003 09:01 PM
