A QUESTION NO ONE WILL ANSWER
Hello all Im new to the site but have a Question i can not get answered.Here is a slight back ground. I own an 2005.5 A4 2.0T
I am getting crazy code such as airbags notfound impact sensors not found and my passenger side mirror no longer goes down in reverse. Also i seem to have a loss of power. Now both the EPC lights and the check engine light is on. Ihave the ROSS TECH scan system and have saved the information and cleared the codes twice. Both times the same codes come up for the airbags,ECT.
Now my question can the ECU be flash updated by the dealership or is it just a replacement needed.
I will try when I get home From work. For now I have taken the car to AUDI.Which does not mean I will let them do the repair just an estimate.
Quick update the Audi dealer has told me 1300 euro or $1924 to replace the ECU and the right side headlamp (w/Xenon and dynamic control). No thank you looking for any ideas and maybe used parts.
you mention airbags and mirror.
can they give you a detailed write-up of the estimate?
I am posting to scans about a week apart
Wednesday,06,July,2011,16:19:21:36232
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUAF68E75A454122 Mileage: 93060km/57824miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 B HW: 8E0 907 115 C
Component: 2.0l R4/4V TFSI 00 0080
Revision: --H02--- Serial number:
Coding: 0104010A18070120
Shop #: WSC 06335 000 00000
VCID: 2045FAC58A53
1 Fault Found:
001537 - Internal Control Module: Memory Check Sum Error
P0601 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 92988 km
Time Indication: 0
Freeze Frame:
RPM: 1334 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.065 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004524
VCID: 2649ECDDE877
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDEF5361B
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul USA 0303
Coding: 01023
Shop #: WSC 65536
VCID: 397337A109C9
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N0004JLX
Coding: 0032607
VCID: 3C7D2EB506FB
Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Coding: 00032607
2 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 21
Reset counter: 99
Time Indication: 0
01221 - Crash Sensor Side Airbag; Driver Side (G179)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02041
Shop #: WSC 06335
VCID: 41835F416119
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 N HW: 8E0 920 981 N
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0020261
Shop #: WSC 66621 142 83106
VCID: 387532A532C3
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: F1E34F819139
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3132
Coding: 11836
Shop #: WSC 06335
VCID: 840D1655BE8B
Part No: 8E1959801G
Component: Tőrsteuer.FS BRM 0706
Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
7 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2649ECDDE877
Part No: 8E0 941 329
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02234 - Right Headlight Power Output Stage (J668)
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0410
Coding: 01205
Shop #: WSC 116736
VCID: 2C5D1EF5F69B
End ---------------------------------------------------------------------
Address 01: DTCs cleared
SCAN 2
Sunday,24,July,2011,16:38:50:36232
69 75 76 77
VIN: WAUAF68E75A454122 Mileage: 93800km/58284miles
VCID: 2045FAC58A53
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 93067 km
Time Indication: 0
Freeze Frame:
RPM: 215 /min
Load: 81.1 %
Speed: 0.0 km/h
Temperature: 17.0°C
Temperature: 17.0°C
Voltage: 11.176 V
Coding: 0004524
VCID: 2649ECDDE877
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDEF5361B
Coding: 01023
Shop #: WSC 65536
VCID: 397337A109C9
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 E
Component: SDAR XM 0080
VCID: 2B5F1DE9F395
1 Fault Found:
02635 - Tuner Not Enabled/Activated
35-00 - -
Coding: 0032607
VCID: 3C7D2EB506FB
Coding: 00032607
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Coding: 02041
Shop #: WSC 06335
VCID: 41835F416119
Coding: 0020261
VCID: 387532A532C3
Coding: 00002
Shop #: WSC 00000
VCID: F1E34F819139
Coding: 11836
Shop #: WSC 06335
VCID: 840D1655BE8B
Part No: 8E1959801G
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 0000019
VCID: 2649ECDDE877
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Coding: 01205
Shop #: WSC 116736
VCID: 2C5D1EF5F69B
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-10 - Open Circuit - Intermittent
69 75 76 77
VCID: 2045FAC58A53
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 92988 km
Time Indication: 0
Freeze Frame:
RPM: 1334 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 39.0°C
Voltage: 12.065 V
Coding: 0004524
VCID: 2649ECDDE877
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDEF5361B
Coding: 01023
Shop #: WSC 65536
VCID: 397337A109C9
Coding: 0032607
VCID: 3C7D2EB506FB
Coding: 00032607
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Coding: 02041
Shop #: WSC 06335
VCID: 41835F416119
Coding: 0020261
VCID: 387532A532C3
Coding: 00002
Shop #: WSC 00000
VCID: F1E34F819139
Coding: 11836
Shop #: WSC 06335
VCID: 840D1655BE8B
Part No: 8E1959801G
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 0000019
VCID: 2649ECDDE877
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Coding: 01205
Shop #: WSC 116736
VCID: 2C5D1EF5F69B
SCAN 2
69 75 76 77
VCID: 2045FAC58A53
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 93067 km
Time Indication: 0
Freeze Frame:
RPM: 215 /min
Load: 81.1 %
Speed: 0.0 km/h
Temperature: 17.0°C
Temperature: 17.0°C
Voltage: 11.176 V
Coding: 0004524
VCID: 2649ECDDE877
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDEF5361B
Coding: 01023
Shop #: WSC 65536
VCID: 397337A109C9
VCID: 2B5F1DE9F395
1 Fault Found:
35-00 - -
Coding: 0032607
VCID: 3C7D2EB506FB
Coding: 00032607
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Coding: 02041
Shop #: WSC 06335
VCID: 41835F416119
Coding: 0020261
VCID: 387532A532C3
Coding: 00002
Shop #: WSC 00000
VCID: F1E34F819139
Coding: 11836
Shop #: WSC 06335
VCID: 840D1655BE8B
Part No: 8E1959801G
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 0000019
VCID: 2649ECDDE877
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Coding: 01205
Shop #: WSC 116736
VCID: 2C5D1EF5F69B
1 Fault Found:
They only gave me part numbers and cost. I do hate to say it but the mentality there was were right just trust us. Plus everything is in German. Now I could translate it ok and my wife sis the rest. The only thing I could get out of the guy was for me to go buy the part and they would charge me 200 euro or $300 to install it and code the keys for me. It was also explained that even though I can use the Ross Tech software to transfer the information the car will still not run until i code the keys.
e40
06-22-2006 01:18 PM
Marc911
10-22-2004 06:23 PM
