Remove doorpanel?
1) Pry the aluminum/wood trim off starting near the cabin side of the door.
4 screws behind that to remove.
2) hidden behind handle is a plastic piece to remove and 2 screws behind that
3) Bottom of door panel is a single long black screw
4) Start at bottom and pry panel off....it does take some force, you may brake some of the clips but you can get replacements
OR use a flathead screwdriver covered in tape and while prying out, press on the clips to compress and they will come off.
5) Lift door panel up and away from door
6) Disconnect the door pull cable, easily done
7) disconnect the electrics. Behid the handle is a connector that slides in. Unlock it and remove and the panel comes off. The connector goes back in easily.
Happy modding
Happy modding
85urq
Audi Original "S" Cars
15
01-06-2006 05:29 PM
Sil4u
17
01-03-2005 04:45 AM
