Stasis Exhaust Fitment Issues
I have a Stasis exhaust on my '08 A4 that was dealer installed and seems to have some fitment issues. It's really close to the top of the s-line valence and there doesnt seem to be any way adjust it. My rubber exhaust hangers are really tight and the right tip is pressing into the valence. The left tip seems to fine now.
![](http://i197.photobucket.com/albums/aa276/veedublvr/IMG00193.jpg)
![](http://i197.photobucket.com/albums/aa276/veedublvr/IMG00195.jpg)
How long have you had this installed? The system changes shape a lot as it gets hot/cold. If this is a new install, give it some time before you move it around.
Here is mine a couple days after install. I have the Votex valance with no clearance issues. The tips move 1-2 inches when it gets hot and it took a few months before I got them adjusted evenly. Yours may be hannging too high on the RH side now, but it may stretch over time.
Its been on the car since March. I did notice it change when hot, but not like this, it always went back when cool. It was normal until it was serviced then I got it back and it was wonky.
Scott is right about needing to know more.
Aftermarket exhaust alignment is a pain in the ****.
I can tell you with my AWE catback, I had to put a longer bolt at the tip fastener location and use washers to build up space on one side (pside, I believe) in order to get the tips more inline with each other. Even that was not enough to get the tips precisely inline with one another, but it did look better. You may want to look at getting the longer bolts and use washers to drop the tips down.
One other thing that seems odd, the photo you posted shows some extreme misalignment in the upward direction, as though something is restricting the lengthwise growth Scott talked about. As a result, the exhaust is "walking" up toward the bumper. I don't know what that could be without seeing more, but it sure seems suspicious. Besides the tip adjustment I mentioned, I would also look a little further back at the center connector bracket where the two pipes split on their way back to the rear bumper. There should be a bolt adjustment there that you may want to loosen to do your tip adjustment like I mentioned above, then tighten the pipe split connector again.
That upward movement towards the bumper is what is killing me. Today they pulled the right rear section and rotated it so slightly to right and readjusted the center brace and its a bit lower now, but much. The installing tech couldnt make sense as to why it moved so much. Its a work in progress I guess.
B8 S FOR
S4 (B8 Platform) Discussion
04-29-2012 12:30 PM
dpattanas
A4 (B7 Platform) Discussion
10-22-2008 08:48 AM
rc1320
14
09-11-2008 09:57 AM
fstjett
18
08-09-2005 07:33 PM
