Tire Rack is telling me 245/40-18. -- ever tried?
After speaking with two Tire Rack professionals, I am being told 245/40-18 is the tire to go with (for my new 18" wheels). I have a stock '06 B7 A4 3.2 quattro (auto). From what I understand, Audi used 235/40-18 on the S-line. But the S-line is lowered a bit from the standard suspension. I want a wheel which feels out the fender well nicely, but I don't want something that rubs or looks like Grandma's grocery-getter.
I checked out the B8 Audi and found it uses 245/40-18.
Looking for some help here before I drop at least $600 on tires.
Thanks!
Thanks!
If you don't have the S-line package you can still have the sport suspension. If you don't have either the sport suspension or the S-line package you're better off not getting 18s as your car will look like it has some sort of lift kit.
Yes to the sport suspension (I think). I have the 5 spoke sport wheels (with 235/45-17 wheels), so I am fairly certain I do. I purchased the car used, so I am not certain.
Lets assume I do have sport. What would be the recommendation.
245/40-18 vs. 235/40-18
What is the width and offset?
Here is 245/40/18 on 8" s-line wheels ET43
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/lip_outside1.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/lip_outside3.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/lip_outside2.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/lip_inside.jpg">
Here is same tire on 8.5" wheel, ET38
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/wheel_turn.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/front-2.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/profile1.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/profile2.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/rear_quarter.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/rear-1.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/close2.jpg">
<img src="http://i165.photobucket.com/albums/u69/imolas4rida/close1.jpg">
As you can see, 245 tire sticks out pretty far on 8" wheel. Keep in mind this particular tire has a rim gaurd and run a little wide. If it's an 8" wheel, I'd go 235 if 8.5" I'd go 245.
Also, if the wheel has an aggressive offset, for example x<ET35 you might rub with 245 under hard cornering. More pics, just click on the sig.
Big thanks for the details pictures!!! However, I am confused on your recommendation. Per your pics, it appears the 245 tire sticks out LESS on the 8" wheel vs the 8.5". Correct?
Here are the wheels I am seriously considering -- the S5 replicas. ET is 45.
Let me know what people think.
Thanks again!<ul><li><a href="http://www.powerwheelspro.com/shop/product_info.php?cPath=21&products_id=41&o sCsid=0f0490eb310dd93eaaa0e675d1e6e7c3">http://www.powerwheelspro.com/shop/product_info.php?cPath=21&products_id=41&o sCsid=0f0490eb310dd93ea
If your goal is to fill out the fenders you'll need some spacers. An 8" wheel with that offset will fit much like the stock s-line wheels I posted. Also make sure they will clear the brakes before you purchase.
I had your setup 245/40/18s and after 12,000 miles the tramlining was unbearable. Alignment and full suspension inspection revealed no problems. New tires cured it. Went with Yoko S-drives this time.
