UM... S-Line Package Tire Iron WTF
Okay... am I retarded or does the tire iron included in the trunk totally not work for anyone with S-Line? And the jack that is included is a POS I am so pissed... it ended up scratching my door blade. I had to jack up my car and the stupid jack shifted (even though it was on a level surface) and scratched the door blade and the bottom body piece. Horrible design... I'm so pissed and I know it won't be covered under warranty but it's disheartening to know they skimped on a freaking jack and tire iron.
I had no problems changing the tire on my S-Line. Did you look at the diagrams and place the jack in the slot? And did you remove the dust caps on the bolts?
I will agree that it's weak that they skipped the safety triangle on the B7... I shoulda nicked the one out of my B6 before I traded it in (like I did the first aid kit).
i had it litterally collapse under the car while changing the spare for a flat...on a perfectly flat, level, dry garage surface. nope, no covered under waranty...the excuse audi used with me was "you should have called roadside assistance." why bother putting a jack there then!?
i escalated the complaint to AoA, same deal there. lesson learned.
you dont set the parking break and leave it in gear the car will roll and crush the jack, i've seen it happen, my girlfriends roommate did it a few weeks back.
I installed 10 mm wheel spacers on the front axle soon after I leased my car. I did look at the instructions in the manual and had no issues. Perhaps the rear axle is a different story.
I know it's not a good idea, but I've used the Audi OEM jack and the jack from wife's car to rotate tires numerous times on my B5.
I've since purchased a floor jack and jackstands, so put down the flamethrowers.
I've swapped out a curb-rashed rim for the one in the trunk in my B7 with no problems. I even put the jack and all tools back in their proper places in the trunk with no problems.
Honestly, I think the design/construction is fine.
Dems my 2ct.
Robert
Dems my 2ct.
Robert
as soon as i got the spare on the thing bent and the car fell, luckily i had the tire on already, but had to go get another jack to finish the job. I just could image what would of happened if the tire wasn't on yet.
Then tried my jack on my car and same thing they are pieces of ****. Thats 2 audi oem jacks and both bent for me, had to use my dads bimmer jack along with mine to hold the car up, the bimmer jack also bent, so i went out and bought one from pepboys and no problems since then.
