A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
vag com for disabling canadian drl, found partial answer through search
Old 08-19-2008, 01:48 PM
citanest's Avatar
Default vag com for disabling canadian drl, found partial answer through search
Module 9 - Central Electrical (B7 specific)
?xxxx Body Style
0 - Sedan
1 - Avant
x?xxx Rain & Light Sensor
0 - Sensor not installed
1 - Sensor Installed
xx?xx Trailer Hitch
0 - Hitch not installed
1 - Hitch Installed
xxx?x Headlight
0 - Halogen without DRL
1 - Halogen with DRL
2 - Bi-Xenon with DRL
3 - Bi-Xenon without DRL
4 - Bi-Xenon with DRL / tail light / license plate light (Not sure how this is different from 2?)
xxxx? Region
1 - Rest of World with Bi-Xenon
2 - Rest of World without Bi-Xenon
3 - USA / Canada with Bi-Xenon
4 - USA / Canada without Bi-Xenon
5 - Special Vehicles (Not sure what this means?)
I found the above info but that doesn't apply to Canadian B7 as it doesn't have the DRL switch to turn it off.
So, should I be using xxx31 then?
I know most US based B7 owners program theirs to xxx21.
thanks in advanced.
Old 08-19-2008, 03:14 PM
Guest
BluDemon's Avatar
Default Ask in the VAG forum.....there's a bunch of different things you can do with the lighting
you might have to code your car to the US and then go from there. I'm a VAG noob so I would have to search the forum and then there is a good section on the ross-tech web site to find answers.
Old 08-19-2008, 05:26 PM
DeMOROlized's Avatar
They do apply to Canadian cars.
Old 08-19-2008, 08:24 PM
A4Audi4Fun's Avatar
Default Confirm works with Canadian cars
As Moro says the codes all work with Canadian B7 cars; our lack of the DRL switch on the dash just means once coded our DRL's are permanently on whereas the US guys have an easy way of quickly turning them on/off as desired.
My 2008 Avant is set at 11021 which gets me DRL's with BiXenon and the 'extras' associated with the ROW config
Old 08-20-2008, 12:21 PM
Default Heh, I should know they work. I have a Canadian car, plus...
...the fact that those codes in his post came from an earlier post of mine from either here or Audizine.
Old 08-22-2008, 10:33 PM
maaliish's Avatar
Default xenons on your car? codes work but work like crap on xenon cars, atleast mine.
Headlights didn't function properly after I did the codes.
Old 08-23-2008, 09:53 PM
A4Audi4Fun's Avatar
Default Assume you mean me...
My vehicle is 2008 B7 2.0T Avant 6MT Canadian Special Edition; Fitted from factory with Bi-Xenon Adaptive lights, auto-dimming mirrors with rain sensing for the wipers, S-Line exterior and interior, memory seats and other options
11023 was the factory setting for Module #9 Central Electronics and I changed it to 11021.
It's all working exactly as I expected it to with the changes.
Old 08-26-2008, 06:22 PM
maaliish's Avatar
hmmm interesting, maybe I'll try that.
Old 12-18-2008, 07:36 AM
maaliish's Avatar
Not sure if anyone is tracking this, but tried the codes and it didn't work on my A4.
Old 12-19-2008, 09:35 AM
A4Audi4Fun's Avatar
Default Re: hmmm interesting, maybe I'll try that.
What was your factory setting for this module then?
Quick Reply: vag com for disabling canadian drl, found partial answer through search
