VagCom doesn't see engine controller
<ul><li><a href="http://www.ross-tech.com/vag-com/old-interfaces/discontinued_interfaces.html">http://www.ross-tech.com/vag-com/old-interfaces/discontinued_interfaces.html</a></li></ul>
Yes the real vagCom (actually second, replaced by Ross when the first cable failed).
Autoscan only found the following controllers:
Address 08: Auto HVAC
Protocol: KW1281
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect.
Protocol: KW1281
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0704
Coding: 00003
Shop #: WSC 06335
Address 16: Steering wheel
Protocol: KW1281
Part No: 8E0 953 549 Q
Component: Lenks?ulenmodul 0601
Coding: 02021
Shop #: WSC 06335
Address 17: Instruments
Protocol: KWP2000
Part No: 8E0 920 951 G
Component: KOMBI+WFS 4 H14 0110
Coding: 0022259
Shop #: WSC 05136
Address 25: Immobilizer
Protocol: KWP2000
Coding: 0022259
Shop #: WSC 05136
Address 46: Central Conv.
Protocol: KW1281
Part No: 8E0 959 433 CG
Component: Komfortger?t T7B 4035
Coding: 11896
Shop #: WSC 06335
Protocol: KW1281
Coding: 00000
Shop #: WSC 00000
Protocol: KW1281
Coding: 00003
Shop #: WSC 06335
Protocol: KW1281
Coding: 02021
Shop #: WSC 06335
Protocol: KWP2000
Coding: 0022259
Shop #: WSC 05136
Protocol: KWP2000
Coding: 0022259
Shop #: WSC 05136
Protocol: KW1281
Coding: 11896
Shop #: WSC 06335
Issue solved, I have the older Key-USB and the new cars require the Hex USB to support the can bus. Is it worth the $175 upgrade price?
barneya4b6
05-25-2006 12:06 AM
iProDrive
VAG-COM Discussion
04-20-2006 01:15 PM
DM-S4
09-29-2003 08:58 AM
