Wheel offset help
Wheel offset help
I'm looking for aftermarket wheels, what is the ET i should be looking for to make the wheels flush with the fender? stock et for my s-line/ tit pkg wheels is 35mm?
Offset you desire depends on wheels width.
If you use an 8.5" wheel ET 35 is about flush in front and close in the rear. If you want to also do a wider tire then 235 though you would want a higher offset (about 38 to 40) to do a 255 tire on a 8.5" wheel.
Okay how much for hubcentric spacers? Looking @ a offset 37 wheel also offset questions, clear it up
Milpitas2.7T
04-27-2002 07:18 AM
siberian
Wheels & Tires Discussion
10-19-2000 09:08 AM
