'09's Any Major Reason to Stay Away
Looking at 09 A4's. Any really big reasons to stay away? I've seen some mention of suspension problems. Will only look at CPO's.
Thank you.
Thank you.
Depends on the options you want. The MY09 with NAV had MMI 2G, while later years have MMI 3G. Also, the rear light are halogen, while newer years have LED lights. There was no real issue with the suspension. The early A4s had solid rubber bushing control arms that made the steering wheel shimmy. They later introduced hydro bushing lower front rear arms to resolve the steering shimmy. If you want a 3.2 V6 A4, MY09 was the only year to have it AFAIK. As for automatic transmissions, they have 6 speeds, while MY11 and newer have 8 speeds automatics with the 2.0TFSI.
(If you can wait until Aug, PM me and don't mind a drive from MA. I'll have mine up for sale. I'm getting a 2013 A6 as I need a bigger Audi).
If you're looking for smooth, linear power, the 3.2 V6 is a terrific engine and as stated above, 2009 was the only year offered on the A4 B8. Aside from the control arm fix and a few minor corrected bugs early on, after 45K miles, I've had zero problems. I absolutely love mine. Find a Prestige model if you can.
The rear lamps are incandescent on the 09. Halogen gas is only in the headlights and front fog lights.
The major recurring flaws were defective materials in the power steering hose that caused a slow speed judder when turning the wheels. A new hose fixed it. Wind buffeting when the sun roof was open and the car had a solid wind deflector. Changing to a notched deflector cured the problem. This caused the radio to sound louder and softer. To hear the effect, open the sun roof, drive 45 mph and push down on the deflector.
Excessive oil consumption is a big problem. Even changing pistons and rings, whole engines, and improving the cam lubrication on a limited number of cars has not always helped. Audi considers 1 QT in 1200 miles normal. Many owners report five times or more miles on a quart.
There are so many things that are right on the car that the above should not put anyone off. By all means get the quattro version. The front wheel drive has poisonous torque steer.
I invite you to try the test factory drivers had me try. Position yourself with your feet flat on the floor behind the pedals. Then move the seat forward so that your knees are slightly bent. Put on your seatbelt and find a parking lot or deserted road where you can accelerate to 50 mph. Stomp on the brake with both feet as hard as you can. You will be blown away at how mannerly the car stops. I was so delighted I left a tip in the tray to the right of the shift lever.
I've had my '09 for 5 weeks and I love it. If you buy a certified car, as I did, you will have plenty of warranty coverage in the event you have any problems. My car is a Premium Plus, so it has a few extra toys and the LED headlights, which is the rage. The 2.0 is very quiet and smooth and I am averaging 28.5 mpg with a mix of city and highway driving. It is, without a doubt, a beautiful automobile.
I would point out that any oil issues that may exist are related to the 2.0 engine. My 3.2 V6 has had zero issues whatsoever, including no oil consumption problems. Also, the power steering hose you mentioned was not really defective per se, just improperly designed.
I'm just have to prepare for the transmission fluid change. I was told that's gonna cost me almost $600 or so. YIKES!!!
