2009 A4 3.2 Problems
My a4 has been experiencing problems getting the air conditioning cold. I bought a rosstech vag com system and ran diagnostics to find fault codes.
My wife has also been complaining that the memorization is not recognizing her key to adjust the seat. I've listed the registered fault codes below. Any guidance would be greatly appreciated.
Could I have a problem with my lin-bus wiring?
__________________________________________________ _______________
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0123.05.080796
Coding: 46002000
Shop #: WSC 02399 823 56573
VCID: 72EBD50BAD17F58E9D3-8027
4 Faults Found:
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 8
Reset counter: 51
Mileage: 109720 km
Time Indication: 0
Date: 2014.01.08
Time: 08:48:53
Freeze Frame:
Temperature: -9.0°C
00457 - Control Module for Network (J519)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 8
Reset counter: 51
Mileage: 109720 km
Time Indication: 0
Date: 2014.01.08
Time: 08:48:53
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 54
Mileage: 109734 km
Time Indication: 0
Date: 2014.01.08
Time: 12:10:21
Freeze Frame:
Temperature: 9.0°C
Temperature: 35.0°C
Load: 0.0 %
Absolute Pres.: 1.0 bar
RPM: 1360 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 13.0°C
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 254
Reset counter: 67
Mileage: 109783 km
Time Indication: 0
Date: 2014.01.26
Time: 14:28:56
Freeze Frame:
Temperature: 10.0°C
Temperature: 90.0°C
Load: 0.0 %
Absolute Pres.: 31.6 bar
RPM: 1320 /min
Speed: 68.0 km/h
Current: 0.000 A
Temperature: 11.0°
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000044392
Coding: 26001091063CAF010000080300003D0D0F1C52080001016100 0000
VCID: 306F1F03639B879E2B7-8065
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010608 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
1 Fault Found:
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 12
Reset counter: 51
Mileage: 109720 km
Time Indication: 0
Date: 2014.01.08
Time: 08:48:00
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001087399
Coding: 00581300000000000000
VCID: F7FD641F467510A62AD-80A2
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 39
Reset counter: 255
Mileage: 100323 km
Time Indication: 0
Date: 2013.01.09
Time: 13:44:51
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007240671
Coding: 011C03204E00410001
VCID: 3F8D4C3FAEC568E6A2D-806A
1 Fault Found:
01705 - Selection Switch for Mirror-Adjust (E48)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 68
Mileage: 108926 km
Time Indication: 0
Date: 2013.11.16
Time: 14:24:50
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H70 0134
Revision: 00002001 Serial number: 0112130055
Coding: 0106023A007A440400B001
VCID: 3365100F928DBC86565-8066
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 11
Reset counter: 82
Mileage: 91003 km
Time Indication: 0
Date: 2012.04.23
Time: 09:32:03
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 82
Mileage: 91003 km
Time Indication: 0
Date: 2012.04.23
Time: 11:26:19
00166 - Access/Start Authorization Switch (E415)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 34
Reset counter: 71
Mileage: 107147 km
Time Indication: 0
Date: 2013.10.22
Time: 17:24:07
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010102
VCID: 6ED3C17BB92FD16E79B-803B
1 Fault Found:
00418 - Front Right DSP Mid-Bass Speaker (R102)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 31
Mileage: 109826 km
Time Indication: 0
Date: 2014.01.29
Time: 17:08:02
Freeze Frame:
Voltage: 11.20 V
Temperature: -5.0°C
Bin. Bits: 00000000
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 12926781082339
Coding: 0CD154
1 Fault Found:
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 41
Mileage: 109056 km
Time Indication: 0
Date: 2013.11.28
Time: 07:05:43
Freeze Frame:
29.08
Bin. Bits: 00000000 00100011
Voltage: 14.40 V
Text: -01,5°C; -0,49bar;3439064785;00h;- 5°C
Coding: 46002000
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 51
Mileage: 109720 km
Time Indication: 0
Date: 2014.01.08
Time: 08:48:53
Freeze Frame:
Temperature: -9.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 51
Mileage: 109720 km
Time Indication: 0
Date: 2014.01.08
Time: 08:48:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 54
Mileage: 109734 km
Time Indication: 0
Date: 2014.01.08
Time: 12:10:21
Freeze Frame:
Temperature: 9.0°C
Temperature: 35.0°C
Load: 0.0 %
RPM: 1360 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 13.0°C
Freeze Frame:
Fault Priority: 2
Reset counter: 67
Mileage: 109783 km
Time Indication: 0
Date: 2014.01.26
Time: 14:28:56
Freeze Frame:
Temperature: 10.0°C
Temperature: 90.0°C
Load: 0.0 %
RPM: 1320 /min
Speed: 68.0 km/h
Current: 0.000 A
Temperature: 11.0°
Coding: 00FD11
Coding: 025028
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 51
Mileage: 109720 km
Time Indication: 0
Date: 2014.01.08
Time: 08:48:00
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 39
Reset counter: 255
Mileage: 100323 km
Time Indication: 0
Date: 2013.01.09
Time: 13:44:51
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 68
Mileage: 108926 km
Time Indication: 0
Date: 2013.11.16
Time: 14:24:50
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 82
Mileage: 91003 km
Time Indication: 0
Date: 2012.04.23
Time: 09:32:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 82
Mileage: 91003 km
Time Indication: 0
Date: 2012.04.23
Time: 11:26:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 34
Reset counter: 71
Mileage: 107147 km
Time Indication: 0
Date: 2013.10.22
Time: 17:24:07
Revision: S1900000
Coding: 0203010102
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 31
Mileage: 109826 km
Time Indication: 0
Date: 2014.01.29
Time: 17:08:02
Freeze Frame:
Voltage: 11.20 V
Temperature: -5.0°C
Bin. Bits: 00000000
Coding: 0CD154
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 41
Mileage: 109056 km
Time Indication: 0
Date: 2013.11.28
Time: 07:05:43
Freeze Frame:
29.08
Voltage: 14.40 V
Roamer
11-29-2004 01:34 PM
