2010 A4 service reminder
Here is a DIY that may help thanks to a post by B_Boy on the Audizine forum:
Per your request, Cabin A/C Filter Install
A/C Cabin Filter - Carbon "Comfort"
Part #: 8K0819439A
The part is manufactured by MANN Filters.
I recommend replacing the cabin filter every 5,000 miles.
I got mine from the dealer for $38.69.
Install Instructions
![](http://i698.photobucket.com/albums/vv350/mbirju2/az/bfa3adab.jpg)
1. Audi A4/S4 B8
2. Audi A5/S5 B8
![](http://i698.photobucket.com/albums/vv350/mbirju2/az/bd587a4d.jpg)
3-4. unscrew 3 plastic wing type nuts (take your time it is a cramped space)
![](http://i698.photobucket.com/albums/vv350/mbirju2/az/c85cd5f5.jpg)
5. remove foam panel by sliding forward and down. Be patient its well fitted in there.
6. Slide the white door to the right and down.
![](http://i698.photobucket.com/albums/vv350/mbirju2/az/eadf7301.jpg)
7. Pull filter out (be sure to have something on the floor in case its really dusty). Also note which side of the filter has the notch and replace accordingly. The filter will bend a bit when removing/installing. If the filter is hard to slide in you inserted it incorrectly, remove and flip it over.
8. Replace white cover, foam panel, and plastic wing nuts. All done! Enjoy fresh clean air!
Part #: 8K0819439A
1. Audi A4/S4 B8
2. Audi A5/S5 B8
Thanks for the help. I've never seen an owner's manual with so little information for the owner who enjoys doing routine maintenance. I have had no luck in finding a service manual for this car either! Thanks again, John
runawayroger
09-11-2004 05:41 AM
Bopha
9
07-03-2003 10:28 AM
