2014 A4 Bluetooth Music Streaming?
Hi all,
I just bought a 2014 A4 yesterday and I was trying to figure out if there was a way to stream your music via bluetooth, or if the only way is to plug in an ipod / SD card? Also, are there specific types of SD cards that you need to use or are any good?
Thanks in advance!
Thanks in advance!
Hi all,
Thanks in advance!
Thanks in advance!
If you have MMI 3G Nav Plus, this should help answer your questions:
https://www.audiworld.com/forums/sho....php?t=2840907
It's C7 oriented but the 2014 A4 Nav Plus system is very similar.
If you have the MMI navigation option, your car supports A2DP Bluetooth streaming. Any paired phone will appear under the device listing when you press the Media key.
stream music
Have you tried viseeO tune2air. I have mine and it works perfect. It streams music via bluetooth..plug it straight into the AMI or on your car's media port, job done.
snagitseven
A6 (C7 Platform) Discussion
455
09-10-2021 02:23 AM
changareth
9
09-13-2015 10:58 AM
