A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old 08-23-2016, 04:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B8) Engine Guides
Print Wikipost
A4 2.0T Quattro-Check engine light on..again!
Old 08-13-2014, 01:25 PM
admittal's Avatar
Default A4 2.0T Quattro-Check engine light on..again!
I bought a used 2009 A4 Quattro 4 months back and and this is the fourth time my check engine light has come on. First it was carbon buildup in the engine which was cleaned up. Then it was cylinder 3 misfiring due to a gasket. The gaskets were then changed. Third it was wear on camshaft which was changed too. Any ideas on what could be causing this? I just moved to Cleveland and work in Mentor, Ohio. Any suggestions on good Audi dealers in the area i could take this to?
Old 08-18-2014, 11:17 AM
fittan's Avatar
Same here....My is a 2010 A4 quattro. Bought it used in 2013, 65K miles. Check engine been on 2 times.
First was the catalytic convertor at 70K. Luckily that is covered under some kind of federal warranty program. Second is for turbo replacement (waste gate won't close/open, common problem) at 75K. Audi offered to cover 50% for this. I have never seen a cat that goes under 100K. Turbo failure at 75K? This is my first Audi and I expect higher maintenance/repair cost but not like that.
Old 08-23-2014, 03:54 PM
Macallan21's Avatar
I can't advise you on how to fix your car.
But. I have an ELM327 bluetooth OBD2 reader from ebay for $13, and I got the Torque app for my android phone for $7. It's been really freaking handy for reading codes on my A4 when the engine misfired, and has helped with my friend's cars too.
You can reset the CEL/codes and see if they return, and log the issues too. That should help you analyze the problems yourself, and through the forums.
Old 08-25-2014, 05:29 AM
dk1
dk1's Avatar
I had my catalytic converter fail at 78K. It is covered until 80K so I was lucky. Otherwise the replacement cost is about $2000, according to my dealer. Otherwise the dealer said that they do see them fail and sometimes much earlier than 80K miles.
What was the cost of turbo replacement?
This is the first and last Audi I own without purchasing an extended warranty. I am already up to $3500 in repairs after warranty expired. The car still drives great but because of potential repair costs I will probably trade it in when B9 becomes available.
Old 08-28-2014, 11:40 AM
fittan's Avatar
It is $3000 but they gave a 50% goodwill discount. End up paying $1500...ouch.
djacobo642
2.0T FSI Discussion
03-13-2018 05:29 PM
djacobo642
New Member Welcome Area
03-13-2018 05:19 PM
03BlkZ
11-09-2013 05:51 AM
LAaudiChica
A4 (B7 Platform) Discussion
01-06-2010 09:14 AM
Lobster
10-25-2005 09:04 AM
Quick Reply: A4 2.0T Quattro-Check engine light on..again!
