A4 B8 No audio, plz HELP!
Hi everyone
Repaired a A4 B8 2009 model (only passenger doors, fender & wheel were damaged), got the car with no battery. so stuck another battery in and sound everything was great. after about 2 weeks car was done but battery was dead. so i got a new one from Audi. but when i connected it, no sound from mmi unit had car @Audi hooked up to their VAS bt their laptop cant read the radio( error comes back - radio not reachable ) anybody out there that can help? also PDC not working since battery change
any info welcome
thanx
any info welcome
thanx
Sounds pretty straightforward. You need to replace the radio since the VAS can't read it.
Any accident can do minor damage to sensitive electronics like the radio or navigation.
I hear what u guys are sayin but like i said earlier, everything was working perfectly when i got the car. both problems only arose after i replaced battery. so what i want to know is did i perhaps pop some sort of fuse that both the park distance sensor and radio are runnin on. as i said, radio & MMI have full funcionality except sound
thanx again for any info
Fuse
Check fuse first.
even if fuse checks ok remove it and reinstall in 30 seconds, this usually resets the sound in the radio.
ask your mechanic to check the fiber optic loop, possible one of the control units is jamming the system, the bluetooth unit is known for doing this specially if water came inside the car.
Thanx S4master1, iflywoe & SeaBlue!
Turns out it ws just a silly 5amp fuse in the trunk causing all the hassles lol! it somehow became dislodged so all i had to do was insert it again and all was well. found the descriptions of all the fuses in Owners manual. Still not sure why Audi dealer couldn't figure that out 4me, car was there for roughly 6hrs...
Thanx again for all the help guys
I hope you told them what the problem was and that in addition to feeling silly, were apologetic for wasting your time.
rory_pamphilon
11-14-2005 12:45 AM
MCPaudiTT - DEFCON 1
09-01-2005 02:55 PM
