Last edit by: IB Advertising
- Audi A4 B8 A4 vs A5 Driving Impressions<br>Important information to help you understand your Audi A4 B8.
A4 Buying Advice -Teen Driver
#21
Thank you sir, I actually just found this one and it seems to be a fair price for 40k. One question though, is this 2009 3.2 that more reliable than say a 2011 2.0? I feel that I have narrowed it down to these two and now it just comes down to which is the "better" car.
This engine did have a problem with excessive oil consumption. This was caused by a problem with the materials used to manufacture the piston rings in many cases. The solution was to replace a lot of pistons and rings. They also replaced whole engines if the cylinder wear was excessive. In the real world they discovered problems with the pressures in the block that were corrected with proper valving and modifications to the ECU to keep block pressures in check.
Some engines had problems with non-specified oil causing carbon build up and coking intake valves. Use the correct oil and filter. Don't be miserly in this department.
There is no timing belt on the 2.0l engine (CAEB) It was changed to a chain. Using the wrong oil, or exceeding the mileage limit of the oil causes extensive wear to the plastic chain guides and then ruin your pocketbook.
The Audi parts are the same price pound-for-pound as BMW, Mercedes, Mini, or VW. The cost to maintain is excessive because of a tiny dealer network. LA is not a problem. Plenty of dealers fighting for your service business.
Be cautious when go to buy. Make sure you get a quattro, and that the car is "certified" with a warranty out to 100K. Dealers make more money on used cars than new, and are all about taking a young person for a financial pummeling. Use a broker if possible from a credit union or Costco to make sure you are protected from the snake in the finance and insurance office.
The difference in price between a premium, premium +, and pretentious (pun intended) are next to nothing in a used car. Get the equipment you want. The largest price differences will be seen in mileage, color, age, and time on market.
Good luck, and enjoy your ride.
#22
#23
There are a couple of items mentioned in the thread that are not true. First is there is no frame on the car. Like most cars these days it has a unibody construction. The car is mostly VW. I know Audi has its own factory and engineering staff, but the A4 is heavily influenced by the availability of the VW parts bin to make the car.
OP, the cars we mentioned, 2011 A4, 2009 A4 2.0T (with oil fix), 2009 A4 3.2.
snag, I have some things in common with the OP and PM'd him about it. Just trying to be honest with him.
#24
this is the one I found...
http://www.autotrader.com/cars-for-s...gIndex=2&Log=0
The car is eligible to be CPO'd by the dealer and while it might cost more, it would extend the warranty out an additional 2 years or 100K miles. A really good idea on any used Audi. If the car is in your area, see if you can get it inspected by an independent shop, particularly looking for any significant body repairs or bring an expert with you to look it over carefully. Ask the dealer if the upper control arms were replaced and if the dual line power steering hose TSBs were done. There was also a revision to the spring loaded pop-up sunroof front air dam that included "pumpkin teeth" to break up the airflow making a noise at speed. Otherwise, no other issues I can think of for a 2009 A4 3.2.
Back in 2009, I tested both the 3.2 and the 2.0t extensively before I purchased. I found the 3.2 to be a smoother engine with overall better acceleration, particularly above 50 mph. The growl sound of the engine was superior to the 2.0t in my opinion. For me at the time, it was a no brainer - 6 cylinder won the day. You should have none of the reported potential 2.0 oil burning issues with the 3.2. I never had to add oil in between 10K services.
The only thing you would be giving up with any 2009 A4 is it has the 2G MMI which lacks a few Nav features of the later 3G MMI versions like scrollable map via the controller **** and more limited built-in Nav POIs. I wouldn't consider this a deal breaker though. Also, the 3.2 used timing belts vs. chain (on the 2.0t) so they would need to be replaced every 75K mi. Finally, the 3.2 gives up about 3 mpg on average over the 2.0t - a fair trade for the 6 cylinder performance in my opinion.
Since I lived with mine for 4 years and 50K miles, let me know if you have any other 3.2 engine questions. I'd be happy to answer them for you if I can.
#25
Sean,
If you want to avoid the early 2.0t engine issues and keep the cost reasonable, consider a low mileage 2009 3.2 V6. This was the only year that Audi offered this tried and true engine in the B8 series and even without a turbo, outperformed the 2.0t a bit due to it's higher 265 HP and was a blast to drive - the smooth engine performed and sounded great. I loved mine and in four years the only issues I had were Audi came up with a fix that replaced poorly designed upper control arms and an upgraded power steering hose. Both have TSBs and would have been performed by now. If I wasn't looking for the next step up to an A6, I would have held on to it well beyond the 50K miles that I put on.
An nice, relatively low mileage '09 3.2 will be harder to find but could be a great choice for you.
#26
#27
Okay so I know it's a luxury car, it'll be relatively expensive to maintain but I was under the impression that this car was more reliable and the cost to own was cheaper than say that of a BMW 328i. How does the Audi A4 compare in terms of reliability to a BMW 328i anyways?
#28
#29
Mellowsean,
I just got a used 2010 A4 premium plus last month so let me share what I've gathered so far.
Yes, the 2009 to 2012 is pretty much the same platform. One difference between 09 and 2010 is the back LED. The former doesn't have it which is a bummer for me. Besides, the price diff is not too much so I scratched out the 09. Between 2010 and 2011, the only diff is the latter has 8 speed transmission. Save you 2 or 3 mpg. Nice but it will probably save me $50/year. Not worth the extra cost. My price range is $20K to $22K so 2012 is out of the question. Obviously at such low price range, I was looking at higher mileage A4 in the 60k mileage.
The 09 to 12 definitely has some "engine oil burn" issue. If you read the manual, Audi delicately thread around this "issue" and suggest that you check the oil level occasionally and top off if necessary. How much are we talking about? Probably a quart every 4000 miles. Since a quart of synthetic cost about $5, it is about $20 to $30/year.
About the trim, you definitely want the Premium plus since it comes with bluetooth (very important for safety) and the LED lights. Hope these helps. Good luck!
#30
A very very small number of 2009 owners have not reported issues with oil consumption. As soon as 2009s started to come off the typical 3 year lease, you could see posts on audizine almost every day like "I got this car a few weeks ago, the oil read full at the time and now it's empty. What's happening?" It seems that there are less reports of excessive oil consumption with 2010 but since it deteriorates gradually we will know for sure if they are any better by the end of the year. I have not heard of excessive oil consumption issues (e.g. 1q per 2k miles or less) for 2011, but they do burn oil. Mine was at 3500 miles per quart when the dealer applied stage one of the fix and it seems that it is about 5-6k per quart now. 2012 are known to not have the oil issue, but it's not that none of them burn absolutely no oil. I have seen a report of half a quarter per 10k miles with 2012.
