A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old 08-09-2016, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B8) Steering & Suspension Guides
Print Wikipost
Annoying front end noise
Old 05-22-2012, 02:59 PM
  #11
Nostromo's Avatar
Can someone describe this noise a little better?
I have a sort of "creaky- squeaky" noise in the rear - I've only noticed it in sloped parking garages where I was going over speed humps at less than 10mph. Sounded simply like a creaky suspension. Don't hear it normally, however and never thought twice about it.
I DON'T have sport suspension. Mine's a 2011. I believe March or April.
Old 05-22-2012, 04:22 PM
  #12
uberwgn's Avatar
We are describing a front end noise. The rear end of my car is silent.
If you've ever driven a car with a front suspension that's dangerously worn out, that's what it sounds like.
Old 05-22-2012, 04:24 PM
  #13
uberwgn's Avatar
Originally Posted by gunsmoker
I believe uber's car was made after mine.
That's right. Mine was built around mid March of 2011.
I wonder if there is a large batch of defective struts produced. OP suggested his were replaced and there was no change in the condition...
Old 05-23-2012, 05:22 AM
  #14
gunsmoker's Avatar
I meant to say mine was built 10/2010 not 2011 and doesn't have it.
Old 05-23-2012, 12:08 PM
  #15
stan211's Avatar
More updates, changed out the front struts at the dealer, guess what, same clanky noise. At this rate, if it continues, I am switching out of the 4 ring circus
Old 05-24-2012, 03:50 AM
  #16
uberwgn's Avatar
Stan, did you have the struts changed within the past day or two?
Old 05-24-2012, 08:58 AM
  #17
stan211's Avatar
Had them changed out less than 48 hours ago. I am not sure what the production date of the actual shocks is (I can check later on, should be on the label). After some driving yesterday, I put about 150 miles extra, I am starting to postulate that it could be looseness in the front differential output flange. Again, just a guess at to what is left as everything else has already been changed or redone
Old 05-25-2012, 04:45 AM
  #18
NavSnipe's Avatar
Has anyone checked the heat shields between the rear driveshaft and exhaust?
The reason I ask is I recently went over a deer carcass on the highway the result caused a clanking/rubbing noise over bumps and during accerleration at times. I could have sworn it was coming from the front end when I was listening from inside the car.
I lifted the car and got underneath and checked for any interference or tight clearances and found the offending heat shield lightly contacting the rear driveshaft. I bent it back into shape and no more noise.
This may not be your problem but it is worth checking.
Old 05-25-2012, 09:44 AM
  #19
stan211's Avatar
Checked all shields and they are in normal shape. Lately, it clearly sounds like something is loose and rattling under the throttle/brake peddle.
Old 05-27-2012, 02:29 PM
  #20
keithandstef's Avatar
Got through the first three posts only: What the HECK does the noise sound like??? Is it a grinding noise, a chirping noise, a whirring noise, a clunking noise? Come on.
If this has been mentioned now in later posts, my apology. Just thought I suggest including that in the original post.
Quick Reply: Annoying front end noise
