A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Audi A4 B8 ECU removal
Old 10-31-2011, 03:15 PM
morphola's Avatar
Default Audi A4 B8 ECU removal
Hi
Does anyone know where the ECU is and how to remove it on a A4 B8 2012 2.0 TFSI Quattro?
Perhaps there exist some ECU removal tutorial for the B8?
Thanks.
regards,
Old 10-31-2011, 08:29 PM
jkownz's Avatar
think i saw a ecu removal on APR's site. I dont think it was an A4. but might be generic.
Old 11-01-2011, 04:20 AM
JD15's Avatar
I believe there are several security bolts you must remove and replace to get to the ECU, which prevents most people from doing themselves. The ECU on DSG versions of the S4 is easier to access.
Old 11-01-2011, 01:23 PM
morphola's Avatar
Well. My current problem is that I have no clue where the ECU is located. I saw a tut on the APR page for the B8 S4 but at that location I have the flushing medium.
When I was searching for the battery I found that in the trunk where the spare tire should be and for all that I know the ECU could be anywhere?
Here is pic of the engine:
regards,
Old 11-02-2011, 11:45 AM
AudiblkA4's Avatar
Remove the shroud under the wipers and the ECU is in a box under that shroud.
Old 11-02-2011, 04:18 PM
ernestolopez's Avatar
Default ECU
Its located underneath cover,infront of steering column,between it and passed the windshield reservoir.You have to unbolt or cut it out,the resoulder it.
Old 11-03-2011, 09:38 AM
morphola's Avatar
Ok.
I removed the plastic cover and found some box under the washer fluid. Could this be the ECU?
If so the I guess I have to remove the washer fluid box first and the get to the ECU box.
Som pic's when plastic cover is removed:
Old 11-03-2011, 09:57 AM
GDawgA4's Avatar
Pull the windshield washer filler neck out and that will expose the cover to the ECU.
Old 06-26-2014, 07:12 AM
liub001048's Avatar
Can someone just upload a video on removing the ECU from Audi A4 B8?
OceanA4.5
11-28-2005 02:31 PM
kepstein
12
05-15-2004 08:35 PM
ouTTatime
03-25-2002 01:24 PM
Gunny to you maggot!
06-01-2001 07:41 AM
Quick Reply: Audi A4 B8 ECU removal
