Audi Certified? Chewed up seat belt buckles?
Should I complain about the 2 seatbelts that are chewed up? there are a few other issues that should have been taken care of via audi cert too. not happy right now. I will let some of the scratches go, but cant let everything go.
Thanks,
Brandon
Thanks,
Brandon
Can you clarify and/or provide pics?
Did you buy the CPO yet? If not just have them fix EVERYTHING now. I just bought a CPO and made them replace two tires and refinish the rims before I signed off. The issues I saw had past the CPO review....I think the CPO inspection is pretty much BS but thats just me.
I saw a Certified Pre-Owned Lexus on the local Lexus dealer lot the other day which had moisture built up on the inside of one of its headlight assemblies. Seriously? Certified?
Take the Certified label from any dealer with a grain of salt. The extent of these certifications seems to be just to put the sticker on the car. It's a used car, and you need to go over it with a fine-tooth comb and have them fix anything which isn't up to your standards.
Doing your own pre-purchase inspection is essential with any used car... even CPO. Bring a VCDS (if you own one, otherwise generic OBD-II will do for most problems) and scan the onboard computer, a $50 paint thinkness tester and a good eye for masking lines, and make them put it up on a lift so you can check underneath. If any dealer gives you resistance to doing this (or taking it to an indie mechanic to check) may be hiding something. Doing some homework like looking at the title history from the state DMV (if you can, some states don't make it public), and vehicle inspection history (if your state has them) can lead to some insights on previous ownership and care as well.
Strjock81
A4 (B7 Platform) Discussion
15
02-11-2008 01:15 PM
1812
12-22-2003 01:58 PM
audi in vt
03-20-2002 11:45 AM
