Avant tail light lens heads up
While changing a back-up light bulb on my 2010 Avant I found that there had been water infiltration and the lens assembly was rusted out. It was replaced by Audi under warranty. I would not have mentioned it but the other day I was checking out another, different coloured Avant at the mall and I noticed that his right rear lens was also fogged as mine had been. I lt th owner know about it.
Well worth checking as a new lens is like $400.00 ! The question is though.. will it happen again? Might it be wise to silicone the seam?
Pretty nice of you to let the another owner know they had a problem.
I don't think I would use silicone because it might make it too hard to get off. I would put a thin coat of vasaline on one side of the water seal and assemble. Then remove and inspect for vasaline transfer to the other side. If not, you need to replace the seal. Remove the vasalene. You can use Flexbar lanolin to make the seal waterproof. Just a finger full wiped on the seal and it will keep water out.
As an aside I am curious as to how many others this has happened to and if is only the right rear affected. Funny though, Audi had to actually see the lens from the dealer to authorize the change.
had this happen twice to my previous B6 avant while under warranty, so i'm hypersensitive to this issue and check my B8 tail lights regularly. luckily, haven't had any issues yet. can't say the same thing about my backup cam...
Jaws567
02-07-2006 12:09 PM
jcw
Audi 100 / A6 (C4 Platform)
11-25-2004 09:12 AM
zoomob
10-23-2004 02:34 PM
