B&O Volume Control when you start the vehicle?
How do I change the stereo settings to not reset the volume everytime I start the car? Even if I turn it down really low, when I restart the vehicle it resets at a higher volume level.
Won't hold a mute setting either (Symphony in Prem+ w/o Nav). Mentioned this to my SA and got "performance to spec" back on the work invoice after AoA thought something was wrong with the unit. After the service they called me back to say that was the way it was designed.
I'd like to know how to change this behavior as well...
The volume automatically drops to a safe limit so that if you turn off after blasting your ears then it's not going to give you a heart attack when you get back in.
I've not found a way of turning this function off but I did tweak the "safe level" so that it was a bit louder i.e. a sensible setting that I can have as my default.
I think I did it in the hidden menu but it was months ago and I can't remember. I'll try and find some info over the weekend.
p.s. I do recall you have to do this per sound source i.e. radio, CD, etc
This unit needs some work, in my opinion. The lack of ability to hold volume/mute after shutdown/restart is unfortunate. The fact that if you "shut off" the system to keep it quiet (only way to prevent mute from being shut off on restart) and then press a button like (car or tel -- maybe ANY button?) on the MMI the sound comes back on is also unfortunate.
You shouldn't have to have to turn the radio on to check the car's oil level or look at the phone book, but you do with MMI.
