B8 A4 Quattro Oil Pressure
So... My Car is saying oil pressure low shut off engine, it only does this if the car isn't at full operating temperature once it hits that it stops but until it finally reached temp, it beeps anytime the car is slowing down under 40mph. What could it be? Some say oil pressure sensor and some say other things. Has anyone encountered this?
Anyways can you see your current oil level on the MMi ? If you can and it states FULL then it implies you have a bad oil level sensor if it actually states in the MMi that the Oil level is below low or LOW then top off your oil so that MMi reads FULL remember our cars burn oil
always fill around 4.76Liters or 5 quarts. to be on the safe side
Low oil pressure and low oil level are two very different things.
I had a remarkably similar issue earlier this month and had the same error pop up. In short, it was part of a recall and fixed for free. The PVC diaphragm was at fault.
2010 A4 "Low Oil Pressure - Turn Off Engine
A little more reading, I found this. I'm taking mine to Audi to have it fixed at no cost.
Go here and put in your VIN: Audi Recall Services by Vehicle Identification Number
Service Campaigns
Crankcase Pressure Regulating Valve REPAIR NEEDED
START DATE
Nov 10, 2015
AUDI ACTION CODE
17F9
DESCRIPTION
On certain Audi vehicles with 2.0L TFSI engine, the diaphragm of the crankcase pressure regulating valve may have been damaged.
REMEDY
Inspect and, if necessary, install a repair kit for the crankcase pressure regulating valve.
Service Campaigns
START DATE
Nov 10, 2015
AUDI ACTION CODE
17F9
DESCRIPTION
REMEDY
EndlessCorners
Audi Original "S" Cars
07-29-2008 05:44 AM
Mike@StartupRacing
04-13-2007 01:48 PM
Luxus Panzer
9
09-29-2004 06:41 PM
TC-GT
03-04-2003 12:58 PM
