B8 Avant -- let's talk about squeaks and rattles
#11
Its easy, but I will provide you with more detail than you probably need. Soak a small kitchen sponge in MTPI. Not too much so that its dripping, but wet. The door seal is pretty soft rubber that runs entirely around the door, and with door closed, mates up against sister seal that lines the car body door frame. Wrap the door seal with the sponge with a soft pinching action and just run the sponge around the entire door seal. Get total coverage. Then notice that the seal has a fold in it. Spread the fold, insert sponge edge and run around entire seal effectively lubing the interior fold. Apply more MTPI to sponge as needed. The sister seal around the car body door frame is much more flush, Just treat the seal all the way around. Do all 4 doors and also open the sunroof and treat those seals. This proceedure really quiets my car big time. Hope it helps you.
#12
COMPLAINT: CUSTOMER STATES THAT THERE IS RATTLE NOISE FRON SUNROOF
WHILE DRIVING
CAUSE: CONFIRMED THE NOISE AND FOUND A RELATED TSB FOR THE
COMPLAINT. ORDERED THE TSB SPECIFIED LUBE.
CORRECTION: CARRIED OUT THE LUBRICATION OF THE SUNROOF AS PER TSB BUT
THE NOISE WAS NOT ELIMINATED. THE NOISE IS EVIDENT ON BODY
FLEXING UNEVEN BUMPS AND WHEN ENTERING AND LEAVING SLOPED
DRIVEWAYS AND IS A CRACK/POP SOUND IN THE SUNROOF AREA. THE
NOISE SEEMS TO BE LESSEND WHEN THE ROOF IS RAISED.
THE NOISE SEEMS TO BE IN THE FRAME OF THE ROOF.
REMOVED ALL PILLAR TRIM TO ACCESS AND REMOVE THE HEADLINER.
ROAD TESTED WITH THE HEADLINER REMOVED. THE SOUND SEEMS OT
BE IN FRAME NEAR THE SEAM OF THE FRONT AND REAR GLASS.
LOOSEND AND RETORQUED THE SUNROOF FRAME BOLTS AND ROAD
TESTED. THE CRACKING NOISE IS NO LONGER EVIDNET.
REINSTALLED ALL TRIM AND CONFIRMED THE SUNROOF NOISE IS
STILL NOT EVIDENT. READJUSTED THE SUNROOF FRONT AND REAR
GLASS POSITIONS FOR CORRECT FIT AND OVERLAP.
ROAD TESTED WITH THE CUSTOMER ON PICK UP TO CONFIRM REPAIR.
THE NOISE CONCERNS WERE NO LONGER EVIDENT.
PARTS------QTY---FP-NUMBER---------------DESCRIPTION--------------------UNIT PRICE-
JOB # 5 1 G-052-141-A2 LIFE GREAS WARRANTY
JOB # 5 2 8K9-898-955 SEC.BOLTS WARRANTY
Pohlposition
03-05-2004 02:37 PM
